跳转到主内容
Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement
你所需要的
  1. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Thanks so much. I was getting seriously annoyed. This worked for me. However, I'll be getting another battery just in case. This helped big
    Ana - 回复
  2. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 步骤 2 中的图像 1,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 步骤 2 中的图像 2,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Remove the battery.: 步骤 2 中的图像 3,3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 步骤 3 中的图像 1,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 步骤 3 中的图像 2,3 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 步骤 4 中的图像 2,2
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement: 步骤 5 中的图像 2,2
    • Make sure that you detach the mid-frame from the inside too.
  6. Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 步骤 6 中的图像 1,2 Samsung Galaxy Grand Prime Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 步骤 6 中的图像 2,2
    • Unhook the ribbon cable clip with the plastic opening tool and remove the audio jack.
    Hello: Do i have to buy and or replace the audio jack?? If so is it connected by wires, or do i just unplug the audio jack n rreplace it with a new one????
    If i am to just put a new audio jack in, where can i buy one to put in my phone??
    Stephen Miller - 回复
结论
30等其他人完成本指南。
Kyle Ruff
于02/04/16注册
6,725 声望
创作了5篇指南
团队
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G3
3 名成员
创作了12篇指南
3条评论
i seem to find myself with the speaker of microphone connected to the back of the housing.. where as i see your photo in step 5 does't have this. how can I replace this element?
jennpindakaas - 回复
I do this but i think my circuit have problem. When i insert aux, the sound play mono. The phone setting is stereo…..
How can i fix this problem?
Replay me on rabbanihootan71@gmail.com
Hootan Rabbani - 回复
How to me a memory card a default storage on grand prime
Ayandaundetsco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 35,943
