当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Wedge the blue plastic opening tool in between the front and side panel.
Move the blue plastic opening tool around the edges between the front and side panel.
Make sure that you detach the mid-frame from the inside too.
Use the plastic opening tool to unhook the ribbon cable clip.
Gently pull on the connector with the tweezers until the speaker comes off.
取消:我没有完成这个指南。
22等其他人完成本指南。
与1其他贡献者
于02/04/16注册
6,725 声望
创作了5篇指南
徽章: 20
+ 17更多徽章
USFT-BLACKWELL-W16S17G3
3 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 35
总计 11,694
