跳转到主内容
简介
This repair is needed to replace the dead battery in your device if it does not turn on, hold a charge, or just flat out wont charge at all.
  1. Samsung Galaxy Grand Prime Battery Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Grand Prime Battery Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Grand Prime Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 步骤 2 中的图像 1,3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 步骤 2 中的图像 2,3 Samsung Galaxy Grand Prime Battery Replacement, Remove the battery.: 步骤 2 中的图像 3,3
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
结论
42等其他人完成本指南。
Damien Harris
于2016年02月04日注册
891 声望分
撰写一个指南
团队
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G3
3 名成员
创作了6篇指南
一条评论
Should I assume that it is the battery at fault when about 3 location seems a bit warm on the board when leaving the charger on?
Noelu Toyotomi - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 17
过去的30天: 108
总计 12,089
