跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide is needed if your midframe on your phone is broken or cracked.
  1. Remove the back cover of phone by lifting up on the back cover tab with  the blue plastic opening tool. Go around the edge of the back cover to completely remove it. Go around the edge of the back cover to completely remove it.
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
  2. Remove the old battery by lifting up on  the thumb tab. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections. Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
  3. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver. Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
  4. Wedge the blue plastic opening tool in between the front and side panel. Move the blue plastic opening tool around the edges between the front and side panel.
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
  5. Make sure that you detach the mid-frame from the inside too. Make sure that you detach the mid-frame from the inside too.
    • Make sure that you detach the mid-frame from the inside too.
结论
40等其他人完成本指南。
Kyle Ruff
于2016年02月04日注册
5,979 信誉积分
创作了5篇指南
团队
USF Tampa, Team 17-3, Blackwell Winter 2016 USF Tampa, Team 17-3, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G3
3 名成员
创作了6篇指南
anyone can tell me how to swap vibrator motor?
Athaariq Ardiansyah Ramadhani - 回复
I need some glue to replace the midframe after having changed it?
Andrea Rossetti - 回复
not necessary
yasir -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 13
过去的30天: 64
总计 10,379
