跳转到主内容
Samsung Galaxy Gear Display Housing Replacement
你所需要的
  1. Samsung Galaxy Gear Display Housing Replacement, Display Housing: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Housing Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Housing Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Gear Display Housing Replacement: 步骤 3 中的图像 2,2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
结论
另外一个人完成了本指南。
Dalt Lasell
于04/12/16注册
543 声望
创作了2篇指南
团队
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G9
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,262
