跳转到主内容
Samsung Galaxy Gear Display Assembly Replacement
你所需要的
  1. Samsung Galaxy Gear Display Assembly Replacement, Display Housing: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Display Assembly Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Gear Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Display Assembly Replacement, Motherboard: 步骤 4 中的图像 1,2 Samsung Galaxy Gear Display Assembly Replacement, Motherboard: 步骤 4 中的图像 2,2
    • On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
  5. Samsung Galaxy Gear Display Assembly Replacement: 步骤 5 中的图像 1,1
    • The motherboard is attached to the display using an adhesive
    • Using a heat gun, heat up the display for 4 to 5 minutes, making sure the move the heat gun around to distribute the heat around the display. This heats up the adhesive making the motherboard easier to remove
  6. Samsung Galaxy Gear Display Assembly Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Gear Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, carefully insert the opening tool in between the bezel and the motherboard and slide it the entire length of the logic board.
    • Slowly pry up the motherboard from the display.
  7. Samsung Galaxy Gear Display Assembly Replacement, Display Assembly: 步骤 7 中的图像 1,1
    • The display assembly is now separated and can be replaced
结论
2等其他人完成本指南。
Joe
于04/11/16注册
279 声望
创作了2篇指南
团队
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G9
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 1,614
