跳转到主内容
Samsung Galaxy Gear Battery Replacement
你所需要的
  1. Samsung Galaxy Gear Battery Replacement, Display Housing: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
    • Be sure your device is turned off.
  2. Samsung Galaxy Gear Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to separate the display housing from from the device.
    • To ensure you don't damage your device, insert the opening tool and slide it the entire length of the gap on both sides of the device.
  3. Samsung Galaxy Gear Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Gear Battery Replacement: 步骤 3 中的图像 2,2
    • Gently pry back the metal flap on top of the connector.
    • Locate the two 2.0 mm black screws and unscrew using a Phillips PH00 bit. The connector will detach from the device.
  4. Samsung Galaxy Gear Battery Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Galaxy Gear Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • After separating the LCD/motherboard from the actual watch itself, the watch should be in two separate pieces.
    • You will only need the watch/strap component so you can set aside the LCD/motherboard component.
  5. Samsung Galaxy Gear Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Gear Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Gear Battery Replacement: 步骤 5 中的图像 3,3
    • Look for the metal bracket that covers and secures the battery in place.
    • Loosen the bracket by prying underneath the metal plating with the plastic opening tool. Remove the bracket and set it to the side.
    • The battery should now be exposed.
  6. Samsung Galaxy Gear Battery Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Gear Battery Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Gear Battery Replacement: 步骤 6 中的图像 3,3
    • Notice the leads attached to the base of the watch. You will need to remove this before you pull the battery out.
    • Using the plastic opening tool, pry underneath the leads and disconnect it from the back of the watch.
    • Slowly tug on the "PULL" tag and remove the battery from the watch.
结论
11等其他人完成本指南。
Edward Yi
于04/11/16注册
424 声望
撰写一个指南
团队
Cal Poly, Team 1-9, Maness Spring 2016 Cal Poly, Team 1-9, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G9
4 名成员
创作了7篇指南
4条评论
WHERE DO I GET A NEW bATTERY & THE TOOLS; IS A COMPLETE KIT AVAILABLE?
rbilello - 回复
where do I get the battery & tools
steve ellis - 回复
“Parts
No parts required.”
I think a battery is required!
cyberjoe3d - 回复
Thank you very much
Adam P NYC
bori0916adam - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 13,316
