跳转到主内容
Samsung Galaxy Fame S6812i Vibration Unit Replacement
你所需要的
  1. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Backplate: 步骤 1 中的图像 1,2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Backplate: 步骤 1 中的图像 2,2
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the backplate from the mid-frame.
  2. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Battery: 步骤 2 中的图像 1,2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Battery: 步骤 2 中的图像 2,2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 步骤 3 中的图像 1,3 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 步骤 3 中的图像 2,3 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove the Mid-Frame: 步骤 3 中的图像 3,3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove Damaged Vibration Unit: 步骤 4 中的图像 1,2 Samsung Galaxy Fame S6812i Vibration Unit Replacement, Remove Damaged Vibration Unit: 步骤 4 中的图像 2,2
    • The vibration unit can be found on the internal side of the mid-frame, in the upper left corner.
    • Using the tweezers, remove the small plastic slip to the left of the unit. The optimal place to grab this is on the small flap on the slip's right.
    • Place the head of the tweezers in the small crevice on the bottom left of the device's housing and push up from under it. This will pop out the vibration unit.
    • These parts are held in via a weak adhesive; some amount of force may be required.
结论
另外一个人完成了本指南。
Taylor
于01/30/15注册
1,165 声望
创作了5篇指南
团队
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G6
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 308
