跳转到主内容
Samsung Galaxy Fame S6812i Speaker Replacement
你所需要的
  1. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery Cover: 步骤 1 中的图像 2,2
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery: 步骤 2 中的图像 1,2 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery: 步骤 2 中的图像 2,2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: 步骤 3 中的图像 1,3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: 步骤 3 中的图像 2,3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: 步骤 3 中的图像 3,3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: 步骤 4 中的图像 1,3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: 步骤 4 中的图像 2,3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: 步骤 4 中的图像 3,3
    • Lift the speaker from the phone using your fingers or tweezers.
结论
2等其他人完成本指南。
Taylor
于01/30/15注册
1,165 声望
创作了5篇指南
团队
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G6
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 850
