跳转到主内容
Samsung Galaxy Fame S6812i Motherboard Replacement
你所需要的
  1. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove Battery Cover: 步骤 1 中的图像 2,2
    • Locate the small indent in the top of the device and use your nails or a spudger to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 步骤 2 中的图像 1,2 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Battery: 步骤 2 中的图像 2,2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 步骤 3 中的图像 1,3 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 步骤 3 中的图像 2,3 Samsung Galaxy Fame S6812i Motherboard Replacement, Remove the Mid-Frame: 步骤 3 中的图像 3,3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 步骤 4 中的图像 1,3 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 步骤 4 中的图像 2,3 Samsung Galaxy Fame S6812i Motherboard Replacement, Unplug LCD Screen from Motherboard: 步骤 4 中的图像 3,3
    • Locate the two ribbon cable connections on the motherboard. GENTLY use the pointed end of the spudger to disconnect the cables. Lift the motherboard out of the phone.
  5. Samsung Galaxy Fame S6812i Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using your fingers or a plastic opening tool, carefully lift the motherboard assembly from the phone.
  6. Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 步骤 6 中的图像 1,2 Samsung Galaxy Fame S6812i Motherboard Replacement, Chassis Removal: 步骤 6 中的图像 2,2
    • On the front face of the motherboard, locate the two #00 Phillips head screws. These hold the SIM card chassis in place.
    • Keep these screws separate from the back plate screws.
结论
5等其他人完成本指南。
Taylor
于01/30/15注册
1,165 声望
创作了5篇指南
团队
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G6
2 名成员
创作了5篇指南
一条评论
How to jumper network problem
Kshitiz khadka - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,193
