跳转到主内容
Samsung Galaxy Fame S6812i Midframe Replacement
你所需要的
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: 步骤 1 中的图像 1,1
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Fame S6812i Midframe Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Fame S6812i Midframe Replacement: 步骤 2 中的图像 3,3
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: 步骤 3 中的图像 1,1
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: 步骤 4 中的图像 1,2 Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: 步骤 4 中的图像 2,2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: 步骤 5 中的图像 1,1
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
结论
另外一个人完成了本指南。
Charles
于10/07/14注册
133 声望
创作了2篇指南
团队
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 573
