跳转到主内容
Samsung Galaxy Fame S6812i Camera Replacement
你所需要的
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: 步骤 1 中的图像 1,1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: 步骤 2 中的图像 1,1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 步骤 3 中的图像 1,3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 步骤 3 中的图像 2,3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: 步骤 3 中的图像 3,3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: 步骤 4 中的图像 1,2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: 步骤 4 中的图像 2,2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: 步骤 5 中的图像 1,1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
结论
6等其他人完成本指南。
Charles
于10/07/14注册
133 声望
创作了2篇指南
团队
USF Tampa, Team 8-2, Leahy Fall 2014 USF Tampa, Team 8-2, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 1,003
