跳转到主内容
Samsung Galaxy Express 3 Back and Recent Apps button Replacement
你所需要的
  1. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
  2. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 2 中的图像 3,3
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
  3. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: 步骤 3 中的图像 1,2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Screen: 步骤 3 中的图像 2,2
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
  4. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 4 中的图像 1,1
    • Detach the screen connector.
  5. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 5 中的图像 2,2
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
  6. Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Express 3 Back and Recent Apps button Replacement: 步骤 6 中的图像 3,3
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
  7. Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): 步骤 7 中的图像 1,2 Samsung Galaxy Express 3 Back and Recent Apps button Replacement, Back and Recent Apps Touch Sensor Button(s): 步骤 7 中的图像 2,2
    • Use a plastic tool to remove back and/or recent tabs circuit buttons.
    • Use a plastic tool as a metal tool can be dangerous to the phone or you.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 550
