跳转到主内容
Samsung Galaxy Core Main and Front Cameras Replacement
你所需要的
视频概述
  1. Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: 步骤 1 中的图像 1,2 Samsung Galaxy Core Main and Front Cameras Replacement, Vibra Motor: 步骤 1 中的图像 2,2
    • Switch-off the phone.
    • Remove the Battery cover and the battery.
    • Remove an inserted SIM and Memory cards.
  2. Samsung Galaxy Core Main and Front Cameras Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Core Main and Front Cameras Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Core Main and Front Cameras Replacement: 步骤 2 中的图像 3,3
    • Remove 9x Phillips screws.
    • With a plastic tool remove the Back cover.
    • The Vibrator is on the other side of the back cover
  3. Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 步骤 3 中的图像 1,3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 步骤 3 中的图像 2,3 Samsung Galaxy Core Main and Front Cameras Replacement, Logic Board: 步骤 3 中的图像 3,3
    • Disconnect one by one:
    • Earpiece/Loudspeaker/Audio Jack connector module flex cable
    • LCD Display flex cable
    • Charging Dock/Antenna/Mic module flex cable
    • Coaxial Antenna cable
    • Carefully remove the Logic Board.
  4. Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 步骤 4 中的图像 1,3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 步骤 4 中的图像 2,3 Samsung Galaxy Core Main and Front Cameras Replacement, Main and Front Cameras: 步骤 4 中的图像 3,3
    • Main / Rear Camera
    • Front Camera
    • With a plastic tool open the Camera flex cable connector.
    • Carefully remove the camera.
结论
7等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,539篇指南
3条评论
Hi, I have galaxy win and the front camera is too bad in quality, i want to replace front camera with galaxy core front camera which is very descent in compare to galaxy win. Please suggest
My email Id: shaikhyassar@gmail.com
Yassar Shaikh - 回复
اكتب عربي
Mjd Mjd - 回复
My mobile Sony m2 my camera low quality... Can I do anything for this problem??!
Mjd Mjd - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 4,493
