你所需要的
Remove the touchscreen with thin tools between the glass and the central cover with the aid of a hair dryer or heat so that you can loosen the adhesive grip
Be careful in the part of the buttons and the flat cable of the touchscreen if you need to use it again and do not replace it with a new one
即将完成!
To Reassemble your device, Follow these instruction reverse order.
结论
3等其他人完成本指南。
由衷感谢以下译者:
it en
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
