跳转到主内容
Samsung Galaxy Centura Speaker Replacement
你所需要的
  1. Samsung Galaxy Centura Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Centura Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Speaker Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Centura Speaker Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Centura Speaker Replacement: 步骤 2 中的图像 3,3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Speaker Replacement, External Speaker: 步骤 3 中的图像 1,1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Speaker Replacement: 步骤 4 中的图像 1,1
    • Gently insert the plastic opening tool into the notch on the side of the device. Apply a firm prying motion to pop open and remove the plastic casing.
  5. Samsung Galaxy Centura Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Centura Speaker Replacement: 步骤 5 中的图像 2,2
    • Locate the black plastic clip at the top of the removed plastic casing. Use the metal spudger to release this clip.
    • Apply a firm prying motion to remove the pink plastic section. The external speaker is a part of this assembly.
结论
Mohsen Alshammari
于02/28/17注册
102 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 的会员
USFT-NANCE-S17S2G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 254
