跳转到主内容
Samsung Galaxy Centura Screen Replacement
你所需要的
  1. Samsung Galaxy Centura Screen Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Centura Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Screen Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Centura Screen Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Centura Screen Replacement: 步骤 2 中的图像 3,3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Screen Replacement, Screen: 步骤 3 中的图像 1,1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Screen Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Centura Screen Replacement: 步骤 4 中的图像 2,2
    • Locate the indentation on the side of the device and gently insert the plastic opening tool into it. With a firm prying motion, the plastic should begin to come apart.
    • Gently pull apart the plastic, and set it aside. The phone should now appear as shown in the second picture.
  5. Samsung Galaxy Centura Screen Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Centura Screen Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Centura Screen Replacement: 步骤 5 中的图像 3,3
    • Pull back the clips located on the right hand side and the upper left side of the phone as shown.
    • After releasing the clips, gently raise the motherboard, exposing the screen from the back.
  6. Samsung Galaxy Centura Screen Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Centura Screen Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Centura Screen Replacement: 步骤 6 中的图像 3,3
    • Gently insert the metal spudger towards the top edge of the back side of the screen.
    • Gently apply pressure to raise the screen from its held position. Continue pulling gently upwards from one side until the screen has been completely removed.
结论
Anthony Maldonado
于02/28/17注册
110 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 的会员
USFT-NANCE-S17S2G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 637
