跳转到主内容
Samsung Galaxy Centura Camera Replacement
你所需要的
  1. Samsung Galaxy Centura Camera Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Centura Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the rectangular groove on the top side of the device.
    • Firmly press the tip of your index finger, or plastic opening tool into the groove, and pull back firmly. The device should pop open as shown.
  2. Samsung Galaxy Centura Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Centura Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Centura Camera Replacement: 步骤 2 中的图像 3,3
    • With the back casing removed, the phone should appear as shown, with a clear view of the battery.
    • Gently pull the battery up with your thumb and index finger. It should come out without resistance.
  3. Samsung Galaxy Centura Camera Replacement, Camera: 步骤 3 中的图像 1,1
    • Find the positions of the seven screws on the back of the device. Use the Phillips #00 screwdriver to remove these 5.0mm screws.
  4. Samsung Galaxy Centura Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Centura Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Centura Camera Replacement: 步骤 4 中的图像 3,3
    • Locate the three metal clips holding the camera in place, and pull these clips away from the camera using the tweezers.
    • Use the tweezers to lift the camera out of the plastic housing. It should come free without resistance.
结论
Austin Erickson
于02/28/17注册
354 声望
创作了3篇指南
团队
USF Tampa, Team S2-G5, Nance Spring 2017 USF Tampa, Team S2-G5, Nance Spring 2017 的会员
USFT-NANCE-S17S2G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 242
