跳转到主内容
Samsung Galaxy Camera Lens or Motherboard Replacement
你所需要的
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: 步骤 1 中的图像 1,1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 4 中的图像 3,3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Camera Lens or Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
结论
8等其他人完成本指南。
Keith Lipking
于09/26/15注册
359 声望
撰写一个指南
团队
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S2G3
4 名成员
创作了4篇指南
2条评论
Would love a video of this, as well.
David CrossmN - 回复
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 3,313
