跳转到主内容
Samsung Galaxy Camera Camera Flash Replacement
你所需要的
  1. 注意:步骤 1-6 源自标记为进行中的 指南
    Samsung Galaxy Camera Camera Flash Replacement, Screen: 步骤 1 中的图像 1,1
    • Begin removing the 3/16" screws for the device.
  2. Samsung Galaxy Camera Camera Flash Replacement: 步骤 2 中的图像 1,1
    • Turn the device and remove the additional 3/16" screws.
  3. Samsung Galaxy Camera Camera Flash Replacement: 步骤 3 中的图像 1,1
    • Turn the device and remove the additional 3/16" screw.
  4. Samsung Galaxy Camera Camera Flash Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Camera Camera Flash Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Camera Camera Flash Replacement: 步骤 4 中的图像 3,3
    • Take the white cover plate off.
  5. Samsung Galaxy Camera Camera Flash Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tools, pry open the camera from the bottom.
    • This may require a moderate use of force because of the sealing glue.
  6. Samsung Galaxy Camera Camera Flash Replacement: 步骤 6 中的图像 1,1
    • Gently pull the connector away from the motherboard.
  7. Samsung Galaxy Camera Camera Flash Replacement, Lens and Motherboard: 步骤 7 中的图像 1,1
    • Unscrew the motherboard's screws. There are 4 3/32" screws and 3 5/32" screws.
  8. Samsung Galaxy Camera Camera Flash Replacement: 步骤 8 中的图像 1,1
    • Unscrew the lens' screws. There are 1 black 4/32" screw, 3 3/16" black screws, and 2 white 5/32" screws.
  9. Samsung Galaxy Camera Camera Flash Replacement: 步骤 9 中的图像 1,1
    • Pull these connectors away from motherboard.
  10. Samsung Galaxy Camera Camera Flash Replacement: 步骤 10 中的图像 1,1
    • Lift the motherboard and lens out of the case.
  11. Samsung Galaxy Camera Camera Flash Replacement, Unscrew: 步骤 11 中的图像 1,1
    • Remove all the screws circled. There is 1 1/8" screw by the flash, 1 9/32" screw that holds the flash button, 2 5/32" screw that is on the grey frame for the flash, and 2 5/32" screws that holds the cable frames on the top left.
  12. Samsung Galaxy Camera Camera Flash Replacement: 步骤 12 中的图像 1,1
    • Unscrew the 3 5/32" screws that cover the battery plate.
  13. Samsung Galaxy Camera Camera Flash Replacement: 步骤 13 中的图像 1,1
    • The black plates on the other side can be removed after these screws.
  14. Samsung Galaxy Camera Camera Flash Replacement: 步骤 14 中的图像 1,1
    • Pull the flash and battery case out of the device.
结论
13等其他人完成本指南。
Richard Hicks
于01/13/15注册
1,262 声望
创作了4篇指南
团队
USF Tampa, Team 1-3, Sullivan Winter 2015 USF Tampa, Team 1-3, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 805
