跳转到主内容
Samsung Galaxy Camera Battery Replacement
你所需要的
  1. Samsung Galaxy Camera Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Lift aside the casing for the battery using a plastic opening tool. This compartment is on the bottom of the camera, not under the lens.
    • The casing is highlighted in the red markup circle.
  2. Samsung Galaxy Camera Battery Replacement: 步骤 2 中的图像 1,1
    • The slot for the battery should look like this. This is the case for the battery.
  3. Samsung Galaxy Camera Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Camera Battery Replacement: 步骤 3 中的图像 2,2
    • Using plastic opening tool, slide battery capture latch back and allow battery to fall out.
    • Insert your replacement battery.
  4. Samsung Galaxy Camera Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Camera Battery Replacement: 步骤 4 中的图像 2,2
    • After the battery has been replaced, close the battery casing.
    • Now replace the casing from step one. Success, the battery has been replaced!
结论
These steps follow completely: there is no need to reverse the order of steps to reassemble.
8等其他人完成本指南。
Derek Brown
于10/24/15注册
168 声望
撰写一个指南
团队
IUPUI, Team 2-3, Wilson Fall 2015 IUPUI, Team 2-3, Wilson Fall 2015 的会员
IUPUI-WILSON-F15S2G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 117
总计 2,122
