跳转到主内容
Samsung Galaxy Camera 2 Screen Replacement
你所需要的
  1. Samsung Galaxy Camera 2 Screen Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Face the camera towards you, then rotate it such that the battery door is facing up and to the right.
  2. Samsung Galaxy Camera 2 Screen Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Camera 2 Screen Replacement: 步骤 2 中的图像 2,2
    • Locate the small latch on the right side of the camera.
    • Slide the latch to the left to open the battery compartment door.
  3. Samsung Galaxy Camera 2 Screen Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy Camera 2 Screen Replacement: 步骤 3 中的图像 2,2
    • Locate the battery, a black cell held in by a small clip (indicated by an outfacing arrow).
    • Pull the clip toward you to release the battery.
  4. Samsung Galaxy Camera 2 Screen Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove and discard the old battery.
  5. Samsung Galaxy Camera 2 Screen Replacement, Screen: 步骤 5 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement, Screen: 步骤 5 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
    • Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
  6. Samsung Galaxy Camera 2 Screen Replacement: 步骤 6 中的图像 1,1
    • Use the screwdriver to remove screws listed in step 2. There are a total of six 4mm screws.
  7. Samsung Galaxy Camera 2 Screen Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 7 中的图像 3,3
    • With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
    • Once this side is free, gently work your way along the edge, all the way around the camera body.
  8. Samsung Galaxy Camera 2 Screen Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 8 中的图像 3,3
    • With the screen freed, gently lay the camera on its face, so that the battery compartment faces up. Use both hands to lift the screen up and away.
    • The screen is still attached to the motherboard by a ribbon cable. Be Gentle as it's very fragile.
  9. Samsung Galaxy Camera 2 Screen Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Camera 2 Screen Replacement: 步骤 9 中的图像 3,3
    • With the screen separated from the main chassis, use the plastic opening tool to gently pry the edge of the ribbon cable connector from the motherboard.
  10. Samsung Galaxy Camera 2 Screen Replacement, Screen Separated: 步骤 10 中的图像 1,1
    • Now the screen is removed.
    • Set the body aside in a safe place.
结论
7等其他人完成本指南。
团队
USF Tampa, Team 14-5, Lacy Spring 2016 USF Tampa, Team 14-5, Lacy Spring 2016 的会员
USFT-LACY-S16S14G5
3 名成员
创作了13篇指南
7条评论
I need to replace the screen and keep the. White around it. How do I do that
nicole deltondo - 回复
You have to use a hair dryer on high on the screen until you can get it loose from the white frame. Carefully pry under the screen with a small screwdriver or a plastic tool to get it loose and then run the plastic tool around the edges until it is loose. It is held in by some type of double sided tape.
clhowey -
after part sales comes only with lcd screen, my question is how do you remove the broken lcd from the housing?
Richard Trinidad - 回复
So what do i use to keep the new one attached?
James - 回复
This is a incomplete guide.
Jasper Walker - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,583
