跳转到主内容
Samsung Galaxy Buds Battery Replacement
你所需要的
  1. Samsung Galaxy Buds Battery Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Buds Battery Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Buds Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • If possible, drain the battery in your Galaxy Buds before performing a battery replacement.
    • Begin by taking off the earbud's rubber wingtip:
    • Grab the tip (where the "R" label is) and gently pull upward on it while slipping it off the bud.
  2. Samsung Galaxy Buds Battery Replacement, Opening up the earbud: 步骤 2 中的图像 1,3 Samsung Galaxy Buds Battery Replacement, Opening up the earbud: 步骤 2 中的图像 2,3 Samsung Galaxy Buds Battery Replacement, Opening up the earbud: 步骤 2 中的图像 3,3
    • Place the bud horizontally into a rubber-guarded vice or a pair of blunt pliers.
    • Apply steady, even pressure to either side of the bud along the main housing seam (the seam between the two arrows). The pressure should break the seal.
    • Only apply enough pressure to create a small gap between the two halves of the bud. If you use pliers, put a cloth between the pliers and the buds to prevent the teeth from digging into the soft plastic.
    You can avoid vise-marks if you use a plastic opening tool, I was able to do it pretty easily. First I applied pressure with my fingernail which created a slight rift, at which point I realized I had a plastic opening tool, so I was able to use that to pry the halves apart, and hold the small opening with my fingernail while I ran the plastic opening tool along the rest of the seam.
    Miles M. - 回复
    Agree with Miles, the opening tool makes it easy to open and won’t destroy the buds. However, take care applying enough pression so the 2 parts don’t split quickly which could break connectors.
    Guillaume - 回复
  3. Samsung Galaxy Buds Battery Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Buds Battery Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Buds Battery Replacement: 步骤 3 中的图像 3,3
    • Once you have created a gap between the two halves of the bud, gently pry them apart with a plastic opening tool.
    • You may need to work your way around the entire earbud with the opening tool. Take your time and do your best not to deform the plastic.
    • Carefully remove the top half of the bud.
    • Be careful when pulling the halves apart! Sometimes the battery assembly gets caught in the case. If the top half of your case doesn't come out cleanly, skip this step and disconnect the cable in step 4 before separating the two halves of the bud.
    • During reassembly, line up the arrows on the two halves of the outer case, then press the halves together until they snap into place.
  4. Samsung Galaxy Buds Battery Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Buds Battery Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Buds Battery Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to lift up and disconnect the press connector connecting the battery/board assembly to the speaker drivers and the other sensors in the case.
    • Once the cable is disconnected, remove the assembly from the bud.
    • During reassembly, slide battery/board assembly into the earbud so that the peg from the outer case fits into the notch in the battery housing. Then reattach the connector to reconnect the assembly.
  5. Samsung Galaxy Buds Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Buds Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Buds Battery Replacement: 步骤 5 中的图像 3,3
    • The remaining components are held together with clips and light adhesive. Work carefully, stay organized, and don't tug on anything too hard.
    • Pry up and remove the plastic cap from the bottom of the battery/board assembly.
  6. Samsung Galaxy Buds Battery Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Buds Battery Replacement: 步骤 6 中的图像 2,2
    • The motherboard consists of two boards wrapped around the battery housing, connected by a flex cable.
    • Use an opening tool to gently pry up one of the boards along its edge, away from the flex cable.
  7. Samsung Galaxy Buds Battery Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Buds Battery Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Buds Battery Replacement: 步骤 7 中的图像 3,3
  8. Samsung Galaxy Buds Battery Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Buds Battery Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to pry up and remove the crescent-shaped cap on the top side of the battery housing.
    Hi...
    My galaxy buds two pro having issue its damaged by some heavy objest fell one thats buds..now its not working coud you please help me to solve that
    vishnuprasad - 回复
  9. Samsung Galaxy Buds Battery Replacement, Removing the battery: 步骤 9 中的图像 1,3 Samsung Galaxy Buds Battery Replacement, Removing the battery: 步骤 9 中的图像 2,3 Samsung Galaxy Buds Battery Replacement, Removing the battery: 步骤 9 中的图像 3,3
    • The bottom of the battery housing has holes, which allow you to push the battery out. The flat side of a spudger fits perfectly through the widest opening, marked here in red.
    • Insert the flat end of a spudger (or another plastic prying tool) into the bottom of the battery housing and push the battery out the other side.
    This part is a bit tricky not to break the plastic cover
    Guillaume - 回复
  10. Samsung Galaxy Buds Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the battery from the battery housing.
    • If possible, transfer the foam strips from the original Galaxy Buds battery to your new one. The foam helps to prevent contact between the battery and other bits inside the bud, and also keeps the battery from moving around inside the housing.
    Gracias por la información, me gustaría saber en donde se consiguen esas baterías, gracias
    Andres Roa - 回复
    My right side shows it's charging but doesn't power on is it a touch issue or battery
    hansomemarvin_ - 回复
结论
To reassemble your device, follow the above steps in reverse order. Use Tesa tape to re-adhere parts that won’t re-adhere with the residual original adhesive.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted back to 100%.
Repair didn’t go as planned? Check out our Galaxy Buds Answers community for troubleshooting help.
38等其他人完成本指南。
Nick Galardi
于04/19/17注册
421 声望
撰写一个指南
20条评论
How to fix not working mic on my galaxy bud
angelofgod jesus's - 回复
Requiere un cambio de pieza electronica correspondiente al microfono, ya que pudo haberse mojado
Pena Ernesto -
My Galaxy buds had the newer CP1254 A3 battery. My Buds were purchased new in August 2019.
Adrian Tolano - 回复
My earbuds touchpad is not working after take shower , can you help how can i repair it
Mohsen Hosseini - 回复
Can this battery replacement be done on the new Galaxy Bud+?
Ed Martin - 回复
can the battery replacement be done in the new Galaxy Bud+
Ed Martin - 回复
Where can I buy a replacement battery in Cape Town South Africa . Its a varta 3.7 v coin battery
Okkie Oosthuizen - 回复
You should change the time… It took my max 2mins
Marek Be - 回复
With step 8 be careful because the plastic is VERY thin and easy to bend but apart from that it is very easy to do and well worth a try.
Matthew Blakeney - 回复
Excelente explicación, pude cambiar la batería de mis audífonos.
Fernando Rios Mejía - 回复
is the battery CP1254 and LIR1254 interchangeable? Notice the screenshot of the repair guide is CP1254 with 3.7v and the replacement battery in the part list is LIR1254 that’s 3.6v.
CK Ng - 回复
Hi CK,
Yes, the two are interchangeable! CP most likely stands for Varta's "Coin Power®" name, while LIR likely stands for a more generic "Lithium Ion Rechargeable".
Arthur Shi -
Many thanks for this contribution! works like a charm!
Guillaume - 回复
Anyone know where to get a replacement battery for the original Galaxy Buds case? Noticing mine is starting to bulge the plastic and the actual earbuds are still good so I don't want to get new earbuds just yet.
MatBa - 回复
In case if anyone run into the same issue as I did. After I replaced the battery, the touch control and mic wasn't working until I went to the Galaxy Wearable app and reset the earbud. Also, on the Galaxy Bud+, you don't need to open up the earbud like in this instruction. You can quite easily pry it open with your finger nails.
Patrick Lui - 回复
Hi Patrick, I noticed you have the Galaxy Bud + I have these too, did you use the LIR1254 battery in this? I noticed some steps were a little different but I cannot seem to source a CP1454 battery to replace the earbud and was hoping the LIR 1254 will work in it's place?
Sabrina -
Worked great, thanks a lot. I had the feeling it went even easier with the Galaxy Bud+.
Marcel Drees - 回复
If the charging case is showing the led earbud as charged but it's completely dead, would you recommend changing the battery out to see if this fixes it?
Sabrina - 回复
@arthurshi Hey Arthur, I ordered LIR1254H battery but when I got to the battery inside the earbud it was a Varta CP1454 A3... I'm waiting for the LIR1254 to be delivered, but will this work? Should I try it? I don't want to fry the earbud
Sabrina - 回复
What is the correct charging voltage and battery model number for the Galaxy Live Buds? I bought an extra pair that were sitting for an extended time (couple of years in an unopened box) went to give them to my GF when her other buds died and I cannot get the brand new never previously used or opened buds to charge because they must be in a LVC (low voltage cutoff state).
Thoughts?
Chris - 回复
添加评论
浏览统计数据:
过去 24 小时: 45
过去 7 天: 359
过去 30 天: 1,686
总计 125,231
