跳转到主内容
Samsung Galaxy Book Pro 360 15" Screen Replacement
你所需要的
  1. Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: 步骤 1 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: 步骤 1 中的图像 2,2
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: 步骤 2 中的图像 1,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: 步骤 2 中的图像 2,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: 步骤 3 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  4. Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: 步骤 5 中的图像 1,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: 步骤 5 中的图像 2,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: 步骤 5 中的图像 3,3
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: 步骤 6 中的图像 1,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: 步骤 6 中的图像 2,3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: 步骤 6 中的图像 3,3
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: 步骤 7 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: 步骤 8 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: 步骤 8 中的图像 2,2
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: 步骤 9 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: 步骤 9 中的图像 2,2
    • Use the flat end of a spudger to pry up the locking flap on the right display cable's ZIF connector.
  10. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: 步骤 10 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to grip the display cable's pull tab and gently pull the cable out of its socket on the motherboard.
  11. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: 步骤 11 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: 步骤 11 中的图像 2,2
    • Slowly pull the right display cable out of its recess.
    • A small clip secures the cable.
    • During reassembly, make sure that the display cable is secured under its clip.
  12. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect and remove the left display cable: 步骤 12 中的图像 1,1
    • Repeat the disconnection and removal procedure on the left display cable.
  13. Samsung Galaxy Book Pro 360 15" Screen Replacement, Open the laptop: 步骤 13 中的图像 1,1
    • Open the laptop until it's completely flat and lay it down with the display and keyboard facing down.
    • Before laying the laptop down, make sure you have a clean surface that is clear of items that could damage the display.
  14. Samsung Galaxy Book Pro 360 15" Screen Replacement: 步骤 14 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement: 步骤 14 中的图像 2,2
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the right screen hinge.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screen screws with new ones labeled #2749.
    • During reassembly, install the screws from left to right.
  15. Samsung Galaxy Book Pro 360 15" Screen Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement: 步骤 15 中的图像 2,2
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the left screen hinge.
    • During reassembly, install the screws from right to left.
  16. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: 步骤 16 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: 步骤 16 中的图像 2,2
    • Lift the screen up and away from the laptop and remove it.
  17. Samsung Galaxy Book Pro 360 15" Screen Replacement: 步骤 17 中的图像 1,1
    • The screen is now detached from the laptop.
结论
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
3等其他人完成本指南。
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
3条评论
This is the display assembly. How do you replace the screen?
Chris Wilson - 回复
Rob -
Is this compatible with the Galaxy Book3 360 2-in-1 15.6" FHD AMOLED Touch Screen Laptop? Model NP750QFG-KA2US. I can't find a good site to confirm compatibility of parts. (FWIW, I don't care if I lose touchscreen capabilities.)
Bret - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 103
过去 30 天: 317
总计 9,130
