跳转到主内容
Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement
你所需要的
  1. Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Access the rubber feet: 步骤 1 中的图像 1,2 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Access the rubber feet: 步骤 1 中的图像 2,2
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: 步骤 2 中的图像 1,3 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: 步骤 2 中的图像 2,3 Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement, Remove the rubber feet: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
结论
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 47
总计 1,290
