简介
Remove the speaker/rear camera assembly from the Samsung Galaxy Attain 4G. This assembly includes the vibrator, rear-facing camera, flash, and loudspeaker.
你所需要的
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
Flip the logic board to the rear side, and using a spudger/plastic pry tool to disconnect the rear camera flex cable.
2等其他人完成本指南。
