跳转到主内容
Samsung Galaxy Attain 4G Rear Housing Replacement
你所需要的
  1. Samsung Galaxy Attain 4G Rear Housing Replacement, Placement: 步骤 1 中的图像 1,1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: 步骤 2 中的图像 1,2 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: 步骤 2 中的图像 2,2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 步骤 3 中的图像 1,3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 步骤 3 中的图像 2,3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: 步骤 3 中的图像 3,3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Rear Housing Replacement, Heads Up!: 步骤 4 中的图像 1,1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Rear Housing Replacement, Screw Removal: 步骤 5 中的图像 1,1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Rear Housing Replacement, Prying: 步骤 6 中的图像 1,1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Rear Housing Replacement, Remove Housing: 步骤 7 中的图像 1,1
    • Lift the rear housing from the display assembly.
结论
4等其他人完成本指南。
Josh Forester
于11/28/10注册
2,497 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 282
