当前版本的文档还未经巡查,您可以查看最新的已查核版本。
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
After removing both flex cables, slowly move the logic board to the left of the screen assembly.
Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
