跳转到主内容
Samsung Galaxy Attain 4G Front Camera Replacement
你所需要的
  1. Samsung Galaxy Attain 4G Front Camera Replacement, Placement: 步骤 1 中的图像 1,1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: 步骤 2 中的图像 1,2 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Door Removal: 步骤 2 中的图像 2,2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: 步骤 3 中的图像 1,3 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: 步骤 3 中的图像 2,3 Samsung Galaxy Attain 4G Front Camera Replacement, Battery Removal: 步骤 3 中的图像 3,3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Front Camera Replacement, Heads Up!: 步骤 4 中的图像 1,1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Front Camera Replacement, Screw Removal: 步骤 5 中的图像 1,1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Front Camera Replacement, Prying: 步骤 6 中的图像 1,1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Front Camera Replacement, Remove Housing: 步骤 7 中的图像 1,1
    • Lift the rear housing from the display assembly.
  8. Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: 步骤 8 中的图像 1,2 Samsung Galaxy Attain 4G Front Camera Replacement, Logic Board: 步骤 8 中的图像 2,2
    • Using your spudger/plastic pry tool, disconnect the headphone jack flex cable.
  9. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 9 中的图像 2,2
    • Using your spudger/plastic pry tool, disconnect the rear speaker flex cable.
  10. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 10 中的图像 1,1
    • Using a spudger/pry tool, carefully remove the vibration motor from its housing. This has a mild adhesive on the bottom.
  11. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 11 中的图像 2,2
    • After removing both flex cables, slowly move the logic board to the left of the screen assembly.
    • Do not try and remove the logic board all the way, as you still have to remove the display assembly flex cable!
  12. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 12 中的图像 1,1
    • Using your spudger/plastic pry tool, disconnect the LCD/Digitizer flex cable.
  13. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 13 中的图像 2,2
    • You have now removed the logic board from the display assembly.
  14. Samsung Galaxy Attain 4G Front Camera Replacement, Front Camera: 步骤 14 中的图像 1,1
    • Using a spudger/plastic pry tool lift the brown ZIF tab on the front-facing camera connector.
    • Do not pry at the black part, as this will damage the connector on the board.
  15. Samsung Galaxy Attain 4G Front Camera Replacement: 步骤 15 中的图像 1,1
    • Carefully pull the camera out of it's connector and set to the side.
结论
3等其他人完成本指南。
Josh Forester
于11/28/10注册
2,497 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 318
