本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
At the top of the device there is a small notch that is used to remove the battery door.
Using a pry tool or your fingernail, pry off the battery door from the main housing.
Place the battery door to the side.
Using a pry tool or your fingernail, pry the battery up towards you.
You have now removed the battery!
即将完成!
结论
另外一个人完成了本指南。
