跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Alpha microSIM Card Replacement
  1. Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 步骤 1 中的图像 1,3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 步骤 1 中的图像 2,3 Samsung Galaxy Alpha microSIM Card Replacement, Removing the Back Panel: 步骤 1 中的图像 3,3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha microSIM Card Replacement, Battery: 步骤 2 中的图像 1,2 Samsung Galaxy Alpha microSIM Card Replacement, Battery: 步骤 2 中的图像 2,2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
  3. Samsung Galaxy Alpha microSIM Card Replacement, microSIM Card: 步骤 3 中的图像 1,1
    • Remove your Micro SIM card from the slot shown.
结论
11等其他人完成本指南。
Tyler
于01/22/15注册
769 声望
撰写一个指南
团队
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G17
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 42
总计 2,673
