跳转到主内容
简介
The Samsung Galaxy Alpha has a micro USB port that can be replaced in the event it is damaged or malfunctioning.
  1. On the back panel of the phone, find the slot that is on the top left side next to the flashlight. Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel. Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Make sure the device is powered down before moving forward. Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
结论
Ryan Butler
于2016年02月09日注册
1,383 信誉积分
创作了9篇指南
团队
iFixit, Team 1-1, Weber Winter 2016 iFixit, Team 1-1, Weber Winter 2016 的会员
FIX-WEBER-W16S1G1
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 74
