To remove the back panel of the device, first find the slot next to the flashlight. Then insert your fingernail or prying tool into the slot and lift gently, around the perimeter, to fully remove the panel.
This step is not needed for replacing the screen. Skip this step if you're only replacing the screen. This step is important for accessing other components.
Use a JIS #000 screwdriver to remove all twelve 3mm screws that surround the back of the phone.
Ensure you have thoroughly heated the adhesive before attempting to pry the screen off.
Do NOT press on the back of the phone while attempting to lift the screen. This will create cracks in the glass.
At the bottom of the touch screen, under the menu buttons, there are connections that can be easily broken. When taking the adhesive off the bottom section, work carefully to prevent damage.
Slide opening pick around perimeter of the glass. Make sure not to push edge too far under the screen.
