跳转到主内容
Samsung Galaxy Alpha Battery Replacement
  1. Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 1,3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 2,3 Samsung Galaxy Alpha Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 3,3
    • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
    • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
    • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
  2. Samsung Galaxy Alpha Battery Replacement, Battery: 步骤 2 中的图像 1,2 Samsung Galaxy Alpha Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Make sure the device is powered down before moving forward.
    • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
    • Locate the slot at the base of the battery and insert your thumb.
    • Push slightly toward the battery and out, away from the phone to free the battery.
结论
9等其他人完成本指南。
Jon Brausch
于01/20/15注册
1,524 声望
创作了2篇指南
团队
Cal Poly, Team 20-17, Maness Winter 2015 Cal Poly, Team 20-17, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G17
4 名成员
创作了5篇指南
2条评论
Not even a full picture of the battery agh! I need to know if I can use note 4 battery
Alex Andrei - 回复
Please also make sure that replacing the battery with a cheap knock off will disable NFC since the antenna is glued to the battery.
vargabp0 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,906
