跳转到主内容
Samsung Galaxy Ace II x Display Digitizer Replacement
你所需要的
  1. Samsung Galaxy Ace II x Display Digitizer Replacement, Display Digitizer: 步骤 1 中的图像 1,2 Samsung Galaxy Ace II x Display Digitizer Replacement, Display Digitizer: 步骤 1 中的图像 2,2
    • This is the first time I have seen this phone in my life.
    • I received it from a friend who informed me I needed to replace the digitiser, and would be rewarded with $20 for doing so.
    • Cracked display, the reason for replacing the glass digitiser on the front.
  2. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 2 中的图像 1,1
    • Locate the small hole on the left side of the phone near the volume rocker, which you can slip your fingernail into to pull the battery casing off.
  3. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by pulling up on the small dip at the bottom, and slide the SIM sideways out of its enclosure.
    • You can also tap the bottom of the phone with the display up against a surface to allow the battery to fall out.
  4. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 4 中的图像 2,2
    • Remove the 8 screws highlighted.
    • With the screws removed, push a spudger no more than a centimetre into the device.
    • Gently pry all around the outside of the phone where the gray plastic meets the glass of the display.
    • The plastic backing will separate entirely from the device.
    • You might have to force it a little, but don't use too much or you risk damaging the plastic or the internal components.
  5. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 5 中的图像 2,2
    • Behold, the motherboard of the phone.
    • Remove the one screw holding down the motherboard.
    • Do not try and remove the motherboard yet!
  6. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 6 中的图像 3,3
    • Gently spudge the power button connector off of the side of the device. Starting from the bottom right corner of where it is in the first picture is the best way to go about this.
    • Gently disconnect the highlighted ribbon cable from the motherboard.
    • DO NOT PULL THE MOTHERBOARD AWAY FROM THE DISPLAY HOUSING YET!
    • The last picture shows the ribbon cable connecting the speaker and headphone jack assembly. You do not need to disconnect this if you are only replacing the digitiser.
  7. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 7 中的图像 2,2
    • Gently lift up the side without the white plastic on it to see the ribbon cable plugged into the bottom.
    • Pull this ribbon cable connector off with a plastic spudger and remove the motherboard from the display chassis.
    • If you need to replace the unit's main camera, it's right here for you to disconnect.
  8. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 8 中的图像 1,1
    • Voila! You now have exposed the belly of the beast! Or at least, the Thin Film Transistor housing.
  9. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 9 中的图像 1,1
    • Disconnect this ribbon cable by flipping the black tab at the very left (relative to this picture) upwards to the right, and gently pulling the ribbon cable out.
  10. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 10 中的图像 1,1
    • Heat the entire front of the display up with a heat gun. A hair dryer will work as well.
    • Stick a finger nail in an area with a small seam - I found one around the top right - and pry it open just enough to fit a spudger.
    • Run it all the way along the edge of the display. There are no sensitive ribbon cables to break, but pay close attention to the silver speaker at the top, and the home button at the bottom.
    • You should also pull up on any surface of the digitiser which has separated from the metal TFT housing. This is to prevent it from re-sticking and introducing aggravation.
    • While using a spudger to remove the adhesive, be sure to always drag the spudger along the digitiser side (towards the glass) and not towards the metal body, or you will scratch the TFT.
  11. Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Ace II x Display Digitizer Replacement: 步骤 11 中的图像 2,2
    • Carefully pull the ribbon cable connector through the slot here, ensuring it doesn't catch on any parts.
    • If you are replacing the digitiser, you do not have to be gentle to the ribbon cable but it is recommended anyway.
    • To reassemble, simply follow all these steps in reverse.
结论
26等其他人完成本指南。
Tom Lube
于05/17/13注册
1,395 声望
撰写一个指南
团队
Apple fan boys Apple fan boys 的会员
Community
51 名成员
创作了44篇指南
14条评论
Thank-you so much for helping me out and for answering my question. But as I said before, my phone is unresponsive to my touch. Do you think that problem will be fixed after replacing the screen as shown above?
Anon - 回复
Hey mate, unresponsive to touch is a sure sign that the digitiser is shot. Getting a new one will almost certainly resolve this issue.
Tom Lube -
my daughter smashed her screen and was ready to have us buy a new phone, I said lets order a screen and see if we can fix it. Well it took 2 weeks for the ebay screen to arrive, and then I had to putup or shutup. It did take about a 1/2 hour and then she put the sim chip in backwards which scared the crap out of me, but for $7.50 her phone is working. Oh I made a mistake and got a black faceplate but she says it looks better in black. So Thanks, and just mention that that screen gets hot with a blow dryer, but a thumb nail works id off just fine
w a powers - 回复
Hey mate! Glad to hear you had a success with the replacement :) Good for you all!
And yes, the screen is meant to get really hot (more hot than is comfortable to the touch) but don't worry if you did it another way :)
Tom Lube -
Well thanks again, two months after replacing the screen the kid broke the new one, so it took two weeks for the new one to show up and the cost went up by 5 cents. One thing in step 9 I had forgot (!@#$ I'm almost 70 I forget lots of stuff) that the lock flips up from the back to the front. And then getting the tab back into position was a real pain. I can only see out of 1 eye so I need to hold the magnifying glass, hold the lock up and fit the tab in. Easy for you young whipper snappers, but for geezers it's a handful
Thanks again great explainations and photos
w a powers - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 35,786
