跳转到主内容
Samsung Galaxy A8 (2018) Display Replacement
你所需要的
  1. Samsung Galaxy A8  (2018) Display Replacement, Display: 步骤 1 中的图像 1,1
    • Before proceeding to change the screen of your Galaxy A8 (2018), press and hold the power button to turn off your device.
  2. Samsung Galaxy A8  (2018) Display Replacement: 步骤 2 中的图像 1,1
    • Insert the SIM Card Ejection tool into the small hole and remove the SIM Card tray.
  3. Samsung Galaxy A8  (2018) Display Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Using a hairdryer, heat up the back of the device to loosen the adhesive.
    • Gently insert a plastic card and opening pick between the glass and frame to create an opening. Carefully separate the rear glass from the rest of the device.
    • Be careful not to overheat the rear glass since it is very fragile.
  4. Samsung Galaxy A8  (2018) Display Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy A8  (2018) Display Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of tweezers, disconnect the clip connecting camera and motherboard.
    • Lift the back panel off of the chassis of the device.
  5. Samsung Galaxy A8  (2018) Display Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 5 中的图像 3,3
    • Use the P2 Pentalobe screwdriver to remove the 14 (0.8mm) screws.
    • Use the Phillips #0 screwdriver to remove the rest of the four 1.5mm screws.
    • Gently leverage with the spudger under the top antenna to lift it.
    • Continue with the spudger to lift and extract the NFC antenna.
  6. Samsung Galaxy A8  (2018) Display Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery using the spudger.
    • Gently lift the speaker and pull it out of the slot.
    • Disconnect the display cables from the device.
  7. Samsung Galaxy A8  (2018) Display Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy A8  (2018) Display Replacement: 步骤 7 中的图像 3,3
    • To soften the adhesive that binds the display panel to the chassis, heat the front panel with the hairdryer for a few seconds
    • To create an opening, insert the opening pick gently between the screen and the chassis
    • Gently slide the plastic card around the screen to take it off the chassis.
    • Be careful not to overheat the centre of the display panel as this can damage it.
结论
14等其他人完成本指南。
团队
1指南评论
My microphone isnt working please help
alpadarkshadow - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 72
过去 30 天: 257
总计 11,103
