简介
This tutorial will show how to replace the back cover of your Galaxy A8.
Opening the phone will damage the waterproof seals. If you do not replace the adhesive gaskets, your phone will work normally, but will no longer be waterproof.
You will likely need replacement adhesive to reattach the back cover.
Turn off your phone.
Prepare an iOpener or hair dryer to soften the adhesive on the back of the A8.
The adhesive is distributed over the outline of the back cover shown in red in the photo.
Move your pick carefully from corner to corner. Leave a pick at each corner once it has been freed to prevent the cover from re-adhering. Repeat for all 4 corners.
Be careful not to damage the fingerprint reader connector when opening the back cover. Disconnect it following the instructions in the next step.
To reassemble your device, follow the instructions in reverse order.
5等其他人完成本指南。
由衷感谢以下译者:
100%
Jerry Wheeler正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
