跳转到主内容
Samsung Galaxy A72 Screen with Frame Replacement
你所需要的
视频概述
  1. Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: 步骤 1 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: 步骤 1 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement, Back cover removal: 步骤 1 中的图像 3,3
    • Warm the device to soften the adhesive.
    • To separate the back cover, use plastic tools, a suction cup and a little ethanol alcohol.
  2. Samsung Galaxy A72 Screen with Frame Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement: 步骤 2 中的图像 3,3
    • Remove the SIM Tray.
    • Unscrew the silver Phillips screws and remove the motherboard plastic cover.
  3. Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: 步骤 3 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: 步骤 3 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement, Motherboard removal: 步骤 3 中的图像 3,3
    • Disconnect the battery.
    • Disconnect the main flex cable.
    • Disconnect the Coaxial antenna cables.
    • Remove the black Philips screw securing the motherboard to the display frame.
    • Keep in mind this screw is different from the others.
    • Use a plastic tool to remove the Motherboard.
  4. Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: 步骤 4 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: 步骤 4 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 1: 步骤 4 中的图像 3,3
    • Remove the silver Phillips screws and with a plastic tool lift up the plastic cover.
  5. Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: 步骤 5 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: 步骤 5 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement, Daughter board part 2: 步骤 5 中的图像 3,3
    • Disconnect the fingerprint sensor.
    • Disconnect the Main flex cable.
    • Remove the black screw securing the Charging board.
    • Keep in mind that this screw is different from the others.
    • Use a plastic tool and gently pick up the Daughter board.
    • Be carefully for the Fingerprint sensor flex cable.
  6. Samsung Galaxy A72 Screen with Frame Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy A72 Screen with Frame Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy A72 Screen with Frame Replacement: 步骤 6 中的图像 3,3
    • Remove the Motor Vibrator.
    • Remove the Fingerprint sensor.
    • Do it slowly and carefully.
    • Before assembling the phone, test the new display using this code:
    • *#0*#
结论
3等其他人完成本指南。
ZFix
于12/09/13注册
191,507 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,487篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 92
总计 4,600
