简介
使用本指南更换 Samsung Galaxy A50 中破裂或破裂的屏幕。
'“注意”':本指南指导你仅在更换屏幕的同时将原始框架和母板留在原处。但是,此手机的某些替换屏幕已预装在新框架(也称为机壳)中,这需要非常不同的过程。在开始本指南之前,请确保零件正确。
'''在拆卸手机之前,请将电池放电至25%以下”'。如果电池被意外刺穿,可能会着火和/或爆炸,但如果放电,则发生的可能性要低得多。
重新组装设备时,你需要使用“替代粘合剂”来重新连接组件。
你所需要的
如果可能,在安装新的粘合剂和重新密封之前,请打开设备并测试维修情况。
固定新屏幕的最佳方法是在屏幕背面粘贴一张定制的双面胶带。
要重新组装设备,请按逆序进行操作。用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
将你的电子垃圾带到R2或e-Stewards认证回收商。维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的社区寻求帮助。
70等其他人完成本指南。
由衷感谢以下译者:
81%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
24条评论
considering it is embedded within the display assembly, any chance that the fingerprint sensor is affected by replacing the screen?
Hi Steve, the fingerprint sensor is not embedded within the display as you can see here. The sensor is fixed under the frame and can be seen through the hole in the frame.
Hey, I followed this procedure to replace my screen and now, whenever I am charging my phone it keeps on rebooting itself every 3-5 seconds, or even when it’s not charging and is just idle. I tried to open it up and realign everything however it didn’t help and kept rebooting. So I am not quite sure what I did wrong and was wondering if you have ever experienced that, and what to do about it.
sounds like you may have damaged the battery in some way, try replacing the battery!
