简介
Use this guide to replace a broken display or cracked glass of your Samsung Galaxy A3.
你所需要的
Switch off your phone.
Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
43等其他人完成本指南。
一条评论
Hi, thank you for this guide. I want to replace my battery, but I don’t see how to re-seal the screen in the end? Do we need to heat the screen the same way we did? Or do we need to use new adhesive?
