跳转到主内容
Samsung Galaxy A20 Motherboard Replacement
你所需要的
  1. Samsung Galaxy A20 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung Galaxy A20 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung Galaxy A20 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
  2. Samsung Galaxy A20 Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,2 Samsung Galaxy A20 Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to lift out the midframe.
  3. Samsung Galaxy A20 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy A20 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool to gently pry up the two motherboard press connectors.
  4. Samsung Galaxy A20 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy A20 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy A20 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Unscrew the single 3.6 mm Phillips screw that secures the motherboard.
    • Use an opening pick to pry up the motherboard.
    • Remove the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 19
总计 52
