简介
This guide will give detailed instructions on how to replace the board that holds the charging and headphone ports. It is most helpful if your device has experienced trauma, damaging this board. Additionally, it may be helpful if both your charging and headphone ports are malfunctioning.
你所需要的
Remove the SIM card and the SIM card tray.
Use an iOpener or heat gun to warm the adhesive that secures the back cover.
Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
Slide the pick around the entire perimeter.
Remove the back cover.
Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
Use an opening pick to pry up and lift out the midframe.
