跳转到主内容
Samsung Galaxy A20 Battery Replacement
你所需要的
  1. Samsung Galaxy A20 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung Galaxy A20 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung Galaxy A20 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
  2. Samsung Galaxy A20 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Samsung Galaxy A20 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to lift out the midframe.
  3. Samsung Galaxy A20 Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy A20 Battery Replacement: 步骤 3 中的图像 2,2
    • Use an opening tool to gently pry up the press connectors on both ends of the two ribbon cables.
    • Remove the ribbon cables.
  4. Samsung Galaxy A20 Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy A20 Battery Replacement: 步骤 4 中的图像 2,2
    • Apply a couple of drops of high-concentration isopropyl alcohol at the top of the battery to help loosen the adhesive that secures it.
    • Use an opening pick to gently pry up the battery.
    • Take care not to bend or puncture the battery.
    • Remove the battery.
    • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 40
总计 88
