简介
This guide was made in the hopes of being able to help repair Samsung galaxy a12.
你所需要的
Unclip flex cables, starting with smaller
Unwind grounding screw
Disconnect antenna
Pop off the main board from Sim tray slot with spudger
Put flex cable out of the way
Credit-card size plastic tool
Wedge between the side of the battery down to the corner and apply isopropyl alcohol
Tilt camera end up to avoid leaking into battery
Pry up the battery being careful to not damage it
55等其他人完成本指南。
6条评论
The volume of my phone is down when receiving a call
Thanks for this. Phone successfully fixed! Just an additional note for people, I noticed my replacement part was missing a lot of the grey gaskets. There are a few of these under both boards, a few small square ones, and a very thin windy one under the bottom board. Not sure if required but I transferred these across to my new one using some tweezers to very carefully peel them off. Make sure you get the "glue" bit underneath to come up at the same time if you can, otherwise you may need extra glue to reattach them. Be careful transferring the volume buttons too, they need to be carefully taken off in the same way and reattached to the new one.
How can i reset my PIN that I had forgotten without a hard reset on my A12?
يمكن تخطى القفل باستخدام اللابتوب
moga2 -
Very good thing you are doing here Big up's
