跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Samsung GT-E2120,请使用我们的维修手册
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: 步骤 1 中的图像 1,1
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: 步骤 2 中的图像 1,2 Samsung GT-E2120 Teardown: 步骤 2 中的图像 2,2
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: 步骤 3 中的图像 1,2 Samsung GT-E2120 Teardown: 步骤 3 中的图像 2,2
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: 步骤 4 中的图像 1,3 Samsung GT-E2120 Teardown: 步骤 4 中的图像 2,3 Samsung GT-E2120 Teardown: 步骤 4 中的图像 3,3
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: 步骤 5 中的图像 1,2 Samsung GT-E2120 Teardown: 步骤 5 中的图像 2,2
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: 步骤 6 中的图像 1,1
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: 步骤 7 中的图像 1,2 Samsung GT-E2120 Teardown: 步骤 7 中的图像 2,2
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: 步骤 8 中的图像 1,1
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
于01/09/11注册
410 声望
撰写一个指南
团队
OPEN OPEN 的会员
Community
82 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 14,023
