跳转到主内容
三星盖乐世Note3服务菜单
视频概述
  1. 三星盖乐世Note3服务菜单, 三星盖乐世Note3服务菜单: 步骤 1 中的图像 1,3 三星盖乐世Note3服务菜单, 三星盖乐世Note3服务菜单: 步骤 1 中的图像 2,3 三星盖乐世Note3服务菜单, 三星盖乐世Note3服务菜单: 步骤 1 中的图像 3,3
    • 输入:*#06# 可以显示IMEI
    • 输入:*#1234# 可以查看Android(Copyright Google)版本
    • 输入:*#12580*369# 可以查看主版本
    • 输入:*#0228# 可以检测电池状态
    • 输入:*#0808# 可以检测USB设置
    • 输入:*#0011# 可以查看服务版本(运营商)
    • 输入:*#0*# 可以服务/测试隐藏功能
    • 输入:*#9900# 可以打开系统转储菜单
    not working in my verizon Note 3
    HIREN PATEL - 回复
    Same. - also Verizon unit. (w/unlocked BL) none worked.. - Absolutely LOVE V/branded phones. :D
    Thor - 回复
    Ussd code not displaying,in my Samsung Galaxy note 3 olleh.every time when I display it says try again.help me please.
    lameck emmanuely - 回复
    If Samsung Note 3 Wi-fi is not turn on how to fix it?
    Shahg - 回复
结论
要还原设备,按照相反的顺序进行操作。
93等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
zhanbohan2008@qq.com正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
16条评论
Does this work with all Galaxy Note 3 phones? I have one from US Cellular and can't seem to get this to work.
atomashaska - 回复
Enter this code first *#22745927 to enable / disable hidden menu.
ZFix -
Yes, unless your mobile phone is installed with a system that is not a Samsung Experience.
zhanbohan2008@qq.com -
You're running a custom ROM. Codes can very between ROMs in certain circumstances. Have you tested these on the stock ROM?
Harley Pisa - 回复
I can not make phone calls with my note 3 after I purchased a activation kit for net10. Im not sure of why is it my apn settings or where do I go from here? I have tried every thing
Donnie King - 回复
could u help me i have samsun glaxy note 3 . when i want to dile number it outomaitcally add +1 then i cant call
i cant calll.
how to remove +1 from my all contact .
engineermasoodazizi - 回复
allso, when i want to from google direct take number then otomatically it added +1
how to remove +1 for contact . i have lots number . when i call , all added +1
pleas help me
please help me my phone is invert colour mode how can change normal mode?
jayasinghpv - 回复
I don't know. You can ask Samsung customer service.
Go to setting type on searche
Inverted and deactivate it .
Ayoubblack Hotmal -
It's Samsung Galaxy note3 and only the touch screen doesn't respond for no reason. I dialed *#0*# nd clicked for touch ….but it didn't work (no hardware damage).Help.
Hannah Baker - 回复
Dear I have N900V samsung Note 3, no any code works on it even *#06#
Pls help
GB KHAN OFFICAL - 回复
I have an /sm_n9005
With a custom room lineàge os àndro pie 9 the self test doesnt come out when i dial *#0*# help
Ayoubblack Hotmal - 回复
I can not make phone calls with my Galaxy j7 after I insert sim card for few calls one or three calls after that “ not registred on network “ command appears on the screen . but the sim card works properly on other phone,I have tried every thing. please help me to fix this problem
eshetu_bkl - 回复
I cannot activate MTN bundles with my Samsung Galaxy Note 3 I can check just credit but to process any other code it cannot
ejabi victor - 回复
Sir my phone mic works on calls with open speaker and not record voice on whattsapp
Malik wajdan ali - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 85,764
