跳转到主内容
Samsung Fascinate Speaker Replacement
你所需要的
  1. Samsung Fascinate Speaker Replacement, Back Case: 步骤 1 中的图像 1,3 Samsung Fascinate Speaker Replacement, Back Case: 步骤 1 中的图像 2,3 Samsung Fascinate Speaker Replacement, Back Case: 步骤 1 中的图像 3,3
    • To remove the back case of the Samsung Galaxy S, you may need a spudger.
    • Identify the slit which is at the bottom edge of the phone.
  2. Samsung Fascinate Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Fascinate Speaker Replacement: 步骤 2 中的图像 2,2
    • Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
  3. Samsung Fascinate Speaker Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Fascinate Speaker Replacement, Battery: 步骤 3 中的图像 2,2
    • Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
  4. Samsung Fascinate Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 Samsung Fascinate Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 Samsung Fascinate Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
    • If the screws are stuck, use the spudger to pry them out.
  5. Samsung Fascinate Speaker Replacement: 步骤 5 中的图像 1,3 Samsung Fascinate Speaker Replacement: 步骤 5 中的图像 2,3 Samsung Fascinate Speaker Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the main case from the LCD touchscreen.
    • Insert the thin edge of the plastic opening tool into the groove between the silver edge and black edge.
    • Run the tool all the way around the edge of the phone until you hear each of the clips detach.
  6. Samsung Fascinate Speaker Replacement: 步骤 6 中的图像 1,3 Samsung Fascinate Speaker Replacement: 步骤 6 中的图像 2,3 Samsung Fascinate Speaker Replacement: 步骤 6 中的图像 3,3
    • Once the clips are detached, separate the main case from the LCD touchscreen.
  7. Samsung Fascinate Speaker Replacement: 步骤 7 中的图像 1,3 Samsung Fascinate Speaker Replacement: 步骤 7 中的图像 2,3 Samsung Fascinate Speaker Replacement: 步骤 7 中的图像 3,3
    • Use the spudger to pry out the grey rubber rectangular component from the main case.
  8. Samsung Fascinate Speaker Replacement: 步骤 8 中的图像 1,3 Samsung Fascinate Speaker Replacement: 步骤 8 中的图像 2,3 Samsung Fascinate Speaker Replacement: 步骤 8 中的图像 3,3
    • Use the spudger to pry along the groove between the speaker and the main case.
    • Once the speaker is unclipped it should pop out easily.
结论
2等其他人完成本指南。
Kevin Carlson
于04/22/11注册
236 声望
创作了6篇指南
团队
Cal Poly, Team 25-25, Garner Spring 2011 Cal Poly, Team 25-25, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G25
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,467
