当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use the plastic opening tool to pry the main case from the LCD touchscreen.
Insert the thin edge of the plastic opening tool into the groove between the silver edge and black edge.
Run the tool all the way around the edge of the phone until you hear each of the clips detach.
这个步骤还没有翻译 帮忙翻译一下
Now that you have unscrewed the 2 black screws, the silver plate holding the device to the motherboard should come right off.
Next, gently pull the Audio Output device off of the LCD touchscreen. It is secured by some weak adhesive and should come off easily.
You are now free to install a new Headphone Jack/Audio Output device.
2等其他人完成本指南。
