当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Insert plastic opening tool under battery.
Pry battery out.
Pry the top cover upward to remove it from the phone.
Remove the top cover.
Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
Two screws from top and two screws from back.
Insert plastic opening tool under top cover.
Using hand slide top cover away from phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert plastic opening tool between back assembly and phone.
Pry the back assembly away from phone.
With plastic opening tool continue prying around the edge of the back assembly.
Pull back panel assembly away from main body.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Use the flat end of a spudger to remove vibrator cable from motherboard.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于07/20/15注册
1,152 声望
创作了9篇指南
徽章: 9
+ 6更多徽章
EWU-ROWLEY-SU15S1G3
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 325
