本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a faulty Vibration Motor.
你所需要的
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
另外一个人完成了本指南。
